help with ball joint
  • Thread starter Thread starter TKEpy237
  • Start date Start date Dec 30, 2006
T
TKEpy237
Indianapolis
Dec 30, 2006
  • Dec 30, 2006
Busted the one of the ball joints on my tubular control arms. I bought the car with the arms all ready installed and the previous owner can't remember what brand they are. I bought a stock ball joint, and it won't fit. The only numbers on the old ball joint are, 1188RALN105. Any help would be great.
bill302
2,131
alabama,gadsden
Dec 30, 2006
  • Dec 30, 2006
probably a gm balljoint, carry it to napa auto parts they have catalogs with dimensions and measurements of specific ball joints and should be able to match it up...do you have any idea about manufacturer or part number for the tubular control arms this will probably help you better locate a replacement...
T
TKEpy237
Indianapolis
Dec 30, 2006
  • Dec 30, 2006
no idea of manufacturer of the control arm, no markings on it at all. Its black and has the provision for a sway bar, thats all I could tell ya. I will try napa tomorrow.
Thanks
HISSIN50
34
129
Dec 30, 2006
  • Dec 30, 2006
I also might try and think of all the different aftermarket control arm manufacturers and then Google Image each one until you find something that looks like yours. When that happens, get more info on that particular arm (like seeing if any part numbers match up).
Good luck.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Dec 30, 2006
  • Dec 30, 2006
Probably better off just buying a new set of arms. If one ball joint fails on its own, chances are the other one will crap out in the not-too-distant future, too, and that's just crappy quality, there. Buying new arms is a more expensive option, but hey ... fix it once and be done, and maybe have a better-performing set while you're at it.
Now would also be a good time to throw on a set of struts or coil-overs, if you can afford 'em, since you'll have everything apart, anyways...
thehueypilot
1,084
Medina,Tennessee
Dec 30, 2006
  • Dec 30, 2006
Post a picture of it and maybe someone can ID the manufacture from the photo?
T
TKEpy237
Indianapolis
Dec 30, 2006
  • Dec 30, 2006
I was in the process of upgrading to sn95 spindles and couldn't get the passenger side ball joint lose. The nut moved on me and I screwed it up beyond repair. I already have a upr bump steer kit, upr caster/camber plates, and unkown coilovers. I already have the rear and driver side done. Just need a stupid ball joint. Other than brakes, there is basically nothing left to upgrade suspension wise. I was just doing the basic sn95 front brakes with ranger axles. It atleast gets me in the door for future wheel and brake upgrades. Thanks again.
T
TKEpy237
Indianapolis
Dec 31, 2006
  • Dec 31, 2006
Thanks for all the help. I think after about 3 hrs of internet time, they are pa racing control arms and the have either trw ball joints or mcquay norris ball joints. I have a part number and hopefully will have the car back on the ground tomorrow.
T
TKEpy237
Indianapolis
Dec 31, 2006
  • Dec 31, 2006
Went to Pep Boys, the factory McQuay Norris ball joints fit like a glove, have no clue why the factory ball joints from Advance and Autozone wouldn't fit. Will be finished tomorrow. By the way got my spindles, calipers, rotors, and axles from a local yard for $150. Bought new drums, pads, and am getting the rotors turned. I might order some stainless brake lines, just haven't made up my mind yet.
HISSIN50
34
129
Dec 31, 2006
#10
  • Dec 31, 2006
  • #10
If the first set of BJ's you got were 'too big', some aftermarket BJ's are indeed a hair bigger to accomodate mushrooming of the boss in the control arm.
In any case, glad to hear you got it whipped.
T
TKEpy237
Indianapolis
Dec 31, 2006
#11
  • Dec 31, 2006
  • #11
No, the o.d. of the other ball joints was at least .200" too big. No where close to fitting the a arm. The new one would almost slide in, press fit. Thanks again for help.
Ball Joints Question
  • 93gtmustang
  • Aug 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2025
AeroCoupe
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
P
Suspension Different height ball joints?
  • pindude80
  • Jun 10, 2024
3K
Fox 5.0 Mustang Tech Jun 12, 2024
limp
T
Resolved Steering won't return to centre
  • Tom77
  • Apr 28, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
Tom77
T
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
