Help with brake lines
  • Thread starter Thread starter Stangzrule
  • Start date Start date Feb 9, 2007
Stangzrule
  • Feb 9, 2007
I am doing a 5 lug swap and have pbr dual piston calipers from a 99 GT. I know lots of people have done this swap and I was wondering how everybody hooked up the front brake lines. I know you can use SS lines from MaximumMotorsports. My car is street only so I don't think I need them. Any suggestions
Silvers
51
  • Feb 9, 2007
The drivers side line hooks right up. The passenger side needs a 3/16 X 1/4 brake line adapter... advance auto part # - 327828.1 put it between new hose and original hard line.
I guess you already know about the 1/4 inch spacers you need under the castle nut.
After you get it all hooked up and bled, turn the tie rod ends out 13 rounds each. This was near perfect on mine,(I used my stock A-arms) but yours might be different.
Stangzrule
  • Feb 9, 2007
Thanks for the info. Yeah I got Steeda X2 balljoints instead of going with a spacer. So I guess I need a new hose for the passenger side from the caliper to the factory hardline(with the new adapter). Do I get a hose for a 99?
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Feb 9, 2007
  • Feb 9, 2007
You only need the passenger side adapter if you buy lines specified for a 94+ Mustang. WIth the 99-04 Gt PBR's you will need 99-04 brake lines (they are the same for all models)
However, if you buy lines specified for a Fox, the two sides will be matched fine and there is no need for the adapter. You just need to make sure you have banjo bolts for the PBR calipers.
Stangzrule
  • Feb 9, 2007
Good info. I think I'm gonna go with 99-04 lines with the adapter. Thanks for clearing that up for me.
Snikt89GT
264
Deland, Florida
Feb 9, 2007
  • Feb 9, 2007
Or you can buy the SN95 brake lines from MM that fit a Fox3. No adapters needed
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Feb 9, 2007
  • Feb 9, 2007
Go stainless lines if you can. There is a big difference in feel with them
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 10, 2007
  • Feb 10, 2007
X2 on the MM Stainless Lines, well worth the extra few bucks!
Stangzrule
  • Feb 11, 2007
Is it worth going with MM Stainless lines on a street driven car?
Mustang5L5
Mod Dude
Feb 18, 2001
43,378
18,123
224
Massachusetts
Feb 11, 2007
#10
  • Feb 11, 2007
  • #10
Yes. I put SS lines onto my DD GT and the difference was night and day. Pedal feel is better and you have more response as soon as you get onto the pedal.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
J
Wheels-Tires Need Some Help - Brakes Upgrade/Wheel fitment
  • jaygee15
  • Dec 8, 2025
  • 3 4 5
4K
Fox 5.0 Mustang Tech Oct 6, 2026
jaygee15
J
