help with cam
  • Thread starter Thread starter rudy herrera
  • Start date Start date Aug 21, 2009
R
rudy herrera
110
Aug 21, 2009
  • Aug 21, 2009
im going to rebuild my motor and i was wondering if i could trow a good cam in there im not looking to stoke my motor or nothing like that since its my daily driver i just want to trow a cam no heads or nothing else is this possible and if it is wat cam should i choose im not looking for a big difference i just want the nice idle and alitle more power any ideas thanks
rbonella
409
@ home
Aug 21, 2009
  • Aug 21, 2009
You should try a custom cam since this is your daily driver. Custom would ensure great driveablility too. Or, if you're looking for a nicer sounding idle and a little more performance you could pick up an E 303 cam from FRPP. They're cheap, sound pretty good, but the technology is pretty old. You might get a 100 different opinions on this subject. Are there any other future mods you're considering? That will come into play with what cam you choose
R
rudy herrera
110
Aug 21, 2009
  • Aug 21, 2009
well i have a air intake i am also going to put in headers with the rebuild
after tha rbuild i plan on getting a new intake manifold with a new trottle body that about it
one of my friends dad has a 86 gt and he put a cam without moding anything else he used this cam Ford Racing B303 have you i heard his car and it sounds good he only has a cam and headers and intake he also did something to the timing other that its stock you think that cam would fit in my car without any problem
CRASH7772
401
NH
Aug 21, 2009
  • Aug 21, 2009
If your not changing the heads then I don't see a real need to change the cam and if you have a roller cam the wear is almost non existent. The stock roller cam is 266°/266° duration, 0.444"/0.444" lift. If you want to add some lift I would get a set of extruded 1.7 roller rockers. I think you could/would benefit more from a set of those.
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • Mindseye007
  • Aug 16, 2026
Mindseye007
