help with car running rich and popping trought inaket
pinsonstang
This is my first post so I'll give some background on the mustang. Its a 88gt california car that I picked up for doing a little work on a guys house. He was tired of messing with it, here is what I know about it. 306 with ported stock heads, ported stock intake, 65mm tb and egr, egr has been blocked off, smog and ac has been deleted, full bbk exhaust, 373 gears, e303 cam, and manual steering. The car dose'nt like to start and when it is running the exhaust smells like gas and burns your eyes, when driving it will pop through intake. So far I have cleaned tb and iac, replaced act, map, ect, and o2 sensors. Installed new fuel filter, cap and rotor, plugs and wires, coil, and tps. The car pulls reel hard from 2500 to 6000 then it will pop throught the intake sometimes, it will idle but driving under 2500 it sputters and bucks. This is a project I hope to turn into a street strip car. thanks for any help.
codes
yes I bought a 30$ scanner from autozone and got a code for the egr and the o2 sensors. The egr is blocked off and the o2s are new. The only other code was idle to high wich is the only way I can get it to run. 1000rpm idle.
What computer?
What size injectors?
Is it tuned?
What MAF?
Have you checked for Vac leaks? If so how?
Did it used to run correctly? What's happened since then? What's is different or has been changed? What was going on when this started?
the computer is stock califonia mas air checked and replaced vacume lines. The car was doing the same thing to the original owner and got frustrated with it. I basicly got the car for nothing. I would like to keep it efi but last resort is to convert to carb. The maf and injectors are stock. There are only three vacume lines on the car one to the brakes one to the fpr and one to the map sen.
So the rest of emmisions control is removed?
Pull the injectors, take them to a parts store that has a flow/test bench and get them cleaned and tested. Replace the o-rings on them while you're at it.
Get a can of engine start fluid and lightly spray around the engine bay. If the motor idles up, you can try an dpin point where it's sucking in air.
Seems like a good place to start.
There shouldn't be any vacuum line connected to the map sensor.
Converting to carb is for quitters. Don't do that.
There shouldn't be any vac line to the MAP sensor. On a mass air car, this is left open to atmosphere to sample air pressure. Only on speed density cars is a vac line hooked up here.
Are you 100% sure it's an original MAF car?
Issues like this are common when people start hacking off emmisions stuff without concern. Hard to tell if the issue is mechanical or a result of removing something that should have been left alone.
What are the actual code numbers? Did you get a code 41 and 91 together? These are usually result of vacuum leaks. Start testing for leaks and remove the vac line to the BAP and leave it open. Also, confirm the computer is in fact a mass air computer. I find it strange someone tried to hook a vac line up here.
What are the codes you got? The actual numbers? How was the EGR disabled?
If you unplug the IAC, what is the absolute minimum idle you can run? If it won't run unless you bump it to 1000, there is an issue somewhere.
I will disconect the vacume line to the map and plug the line. When the tempature gets above freezing I will do the spray test. As far as the the computer and maf, I cant remember the number on the computer but it is a cali mass air ecm the maf looks stock. The car is an 88 so I asumed its a cali mass air car. The egr was unpluged and a block off plate was installed. When the weather warms up I will pull the codes. thanks for all the help I think the guy that owned it before me was trying to strip it down for dragracing. What dose having the injectors cleaned and tested cost typically.
Backfiring out the intake is either a valve stuck open or a lean mixture or spark plug wire(s) connected to the wrong cylinder(s). Check compression on all cylinders and then look for vacuum hoses loose, cracked, or misconnected. Check the line for the vapor recirculation system – it is easy to knock loose and not see it when you connect the air pump plumbing. If the vacuum line for the EGR valve and the air pump are cross connected, some very strange things can happen. Check the mass air flow electrical connection and see that it is tight, the same goes for the fuel injection wiring harness connectors up on top of the manifold near the firewall.
Sticking valves: If a intake valve is bent, has a bad spring or is misadjusted, the engine will sometimes backfire through the intake. Use a vacuum gauge connected to any convenient spot on the intake manifold. Run the engine at 1000 RPM & look for 18-21 inches of vacuum with a steady needle. A problem intake valve will make the vacuum gauge needle sweep 5-10 inches.
Lean fuel mixture breaks out into several sub categories:
A.). Vacuum leaks
B.) Air entering the intake without passing through the MAF on Mass Air cars (89-95 models).
C.) Failure of the MAF, BAP/MAP (Baro or Manifold Air Pressure, same sensor, different name), ACT (air charge temp), or ECT (engine coolant temp). These should set a code in the computer.
D.) Leaking exhaust gases from EGR valve at WOT or EGR opening when it should not be open.
E.) Poor fuel delivery due to bad fuel pump, clogged filter or bad fuel pump wiring. Look for low pressure or fluctuating pressure. Standard injector pressure is 39 PSI at idle, with the vacuum line disconnected from the regulator and capped.
F.) Clogged fuel injectors.- see the cylinder balance test below
H.) Fuel injector wiring problems causing injector not to deliver rated flow.
I.) Computer problems: (computer problems are not common like sensor problems)
J.). ROM has bad data in fuel or timing table. This should also set a code in the computer.
K.) Failure of one or more of the computer's driver transistors for the fuel injectors. No code set on this one. Use a noid test light to test the injector wiring & injector drivers,
L.) MAF calibration off or mismatched to injectors.
M.) ACT or ECT bad. Sometimes the sensors will be off calibration, but not bad enough to set a code. If they falsely read too high a temp, the engine will back off fuel delivery.
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
I had to install a o2 wiring harness would it matter that I got it out of a 90gt. I also noticed alot of the weather connector snaps are broke and there are places where the motor harness has been patched. I was thinking about getting a new injector harness?
Were it me, I wouldn't go ripping harnesses out etc. until I'd pin pointed a problem. Injector cleaning doesn't cost a whole lot. Call around to automotive stores/machine shops until you find one with a flow-bench for injectors. Places like NAPA are often a good start.
