Okay guys i fix the isue with my carb got it to idle just were i whant to and i think i set the idle screws just right. when i did my carb conversion i kept the stock efi fuel pump and just ran a carb fuel regulator.Well know the reg is not being very accurate it reads like 9 psi one day the next 6 and sometines even 3.so i decided to do right im be using a electric fuel pump kit from jegs and a fuel pickup tube. my question is the pickup tube has a return style tube also will i need that or can i just cap it off. As far as i know it will be going from the tube trew the pump into the engine compartment to the reg and finally to the carb correct me if i wrong but whant to do it right this time.
heres the the fuel kit that im geting http://www.jegs.com/i/JEGS+Performance+Products/555/100804/10002/-1
and here is the pick up tube http://www.ebay.com/itm/190634642986?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
