help with caster/camber
fivespeedsteed
Oct 17, 2003
748
22
69
Richmond, VA
my front tires are wearing badly on the inside. this is negative camber correct? im runing stock junk right now, and im wondering if the coils are just worn out and are letting the car sag down to a lower ride height, which is throwing off the camber. can i get caster camber plates (MM) to fix this? are these hard to install, and if i get them on will alignment people know how to fix the negative camber and work the mounts? thanks.
You can eyeball camber yourself - on a stockish ride height, you should not have excessive neg camber though. A severe toe-out issue can wear the insides of tires as well.
MM CC plates are the most ubiquitiously liked. As for an alignment shop knowing what they are doing, it's hit or miss. It can take some phone calls to find a shop you're comfy with.
Good luck.
