Help With Codes!
  • Thread starter Thread starter Mavrick
  • Start date Start date Aug 3, 2004
Mavrick
2,264
Collingwood, ON
Aug 3, 2004
  • Aug 3, 2004
Ran the codes today and got..
54 - intake air charge temp sensor circuit oipen, vane air flow sensor out of range
82 - air diverter selenoid circuit fault or supercharge bypass circuit fault.
The car has been sitting in the garage for a while, and i ran these codes after the car got to temp (160). Since it has been sitting, i have installed all the emissions equipment back up to the car.
Could someone let me know whats going on here, what the possibilities may be?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 3, 2004
  • Aug 3, 2004
Code 54 – ACT sensor out of range. Broken or damaged wiring, bad ACT sensor. Note that that if the outside air temp is below 50 degrees F that the test for the ACT can be in error.
ACT & ECT test data:
The ACT & ECT have the same thermistor, so the table values are the same
Pin 7 on the computer - ECT signal in. at 176 degrees F it should be .80 volts
Pin 25 on the computer - ACT signal in. at 50 degrees F it should be 3.5 volts. It is a good number if the ACT is mounted in the inlet airbox. If it is mounted in the lower intake manifold, the voltage readings will be lower because of the heat transfer. Here's the table :
68 degrees F = 3.02 v
86 degrees F = 2.62 v
104 degrees F = 2.16 v
122 degrees F = 1.72 v
140 degrees F = 1.35 v
158 degrees F = 1.04 v
176 degrees F = .80 v
194 degrees F = .61
Ohms measures at the computer with the computer disconnected, or at the sensor with the sensor disconnected.
50 degrees F = 58.75 K ohms
68 degrees F = 37.30 K ohms
86 degrees F = 27.27 K ohms
104 degrees F = 16.15 K ohms
122 degrees F = 10.97 K ohms
140 degrees F = 7.60 K ohms
158 degrees F = 5.37 K ohms
176 degrees F = 3.84 K ohms
194 degrees F = 2.80 K ohms
Code 82 - use the test path for codes 44 & 94 since it checks all the diverter valve functions
Codes 94 & 44 - AIR system inoperative - Air Injection
Check vacuum lines for leaks, & cracks. Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump the pump's output to the atmosphere or pass it to the next valve. The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheelwell turn the vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire. Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source any power to actuators, relays or injectors, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Mavrick
2,264
Collingwood, ON
Aug 3, 2004
  • Aug 3, 2004
I'm a little too applied for those instructions, but i'll try reading them over a few times..
So code 82 has something to do with emissions equipment? And code 54 (the ACT), is that also with the emissions system?
Mavrick
2,264
Collingwood, ON
Aug 5, 2004
  • Aug 5, 2004
ttt
5.0guy
320
MI
Aug 5, 2004
  • Aug 5, 2004
how do u apply vacuum to the valves?
Billcas
NY
Aug 5, 2004
  • Aug 5, 2004
You can use a hand held vacuum pump also known as a brake bleeder tool. It has a small vacuum gauge on it. Most auto stores have them.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 5, 2004
  • Aug 5, 2004
Use engine vacuum - cheap and easy to find. Just look at the vacuum tree near the wiper motor. Ther's a spare port capped off that you can use.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
