The car is the 89 Notch in my signature with an AOD. These are the codes I just pulled with car in Neutral. Check engine light came on and it runs rough.
KOEO codes
67 = Neutral safety circuit failure (Car starts only in Park or Neutral)
85 = Canister Purge Solenoid circuit failure (Not installed)
Codes from Continues Memory
33 = EGR valve opening not detected. (EGR eliminator plug installed and vaccum line capped)
41 = HEGO sensor circuit indicates system lean (right side). New less than 300 miles.
91 = No HEGO switching detected always lean (left side). New less than 300 miles.
Wiring harness has been checked out and computer has been checked also.
Thanks for any help.
KOEO codes
