Help with cruise control
  • Thread starter Thread starter Redfire 05
  • Start date Start date Jun 26, 2005
First Prev 2 of 2
trents99
438
Hampton, GA
Nov 10, 2005
#21
  • Nov 10, 2005
  • #21
JB66 said:
1. Does your horn work?
2. Do your brake lights work?
3. There is an emergency release vacuum dump valve above the brake light switch which is activated by the arm that the brake pedal is attached to. Findit. Plug the vac. line with a pencil and see if the cruise works. Come back and I'll explain how to adjust it.
My cruise doesn't work either. Brake lights work but horn DOES NOT work. All fuses inside are okay.
J
JB66
565
New York
Nov 10, 2005
#22
  • Nov 10, 2005
  • #22
Horn problemcould be relay or clockspring. Up under the center of your dash near the warning chime is the horn relay. When you press the horn button, you shoule hear a faint click. Or you can pull the connector and see if there is power to the LB/W wire all the time (connector off). Also if the DB wire has power when the horn button is pressed(connector on). Or if the Y/LG wire shows continuity to ground with the horn switch pressed(connector off). What does this have to do with the speed control? The speed control "ON" switch picks up the power to turn it on from the Y/LG wire.
First Prev 2 of 2
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
C
Electrical 2 step on cruise control button
  • colehelm
  • Aug 14, 2024
Fox 5.0 Mustang Tech Aug 20, 2024
Mustang5L5
