help with dss331
76bronco
9
I am new to this forum. I have a 76 bronco and put a dss 331 bullet short block in last week. I have trick flow twisted wedge heads, an e cam advanced 4 degrees to lower the power in the rpm band. a stock 5.0 intake w/19# injectors. An x pipe with no cats. The engine should be around 10.5 compression according to dss with the twisted wedge heads. I have the timing set at 4 degrees right now with the spout unplugged. I smell fuel at an idle and it does not pull quite as well as I expected. The egr is bypassed and has an egr eliminator built into the RJM harness. I thought I would need 24# injectors and it does seem to lean out at higher rpm but I can really smell gas at idle. No codes except egr not working because of the bypass. I have the stock fpr and msd fuel pump. new o2's. Any idea what could cause the fuel smell at idle and should I get 24# injectors and new mass air calibrated for them. Thanks for any help
Not sure exactly might be causing the fuel smell but I would say that the stock intake is to small for a 331. Its a bottleneck on the 5.0s so on a 331 I would imagine it becomes more noticable. If you are on the cheap find an explorer intake and swap it out. Since you have no EGR anyway any year explorer intake will work for you, the later years I believe 98 and up do not have the provision for the internal EGR passages.
On a 302 the factory intake is a bottle neck. Now you have more cubic inch's to fill with air and fuel mixture so the factory intake becomes more of a bottle neck. The holley systemax II intake is a very nice piece. what TB do you have? just stock? think bout up grading that aswell.
bump up the timing when it starts to ping jus a lil bump it back till it stops for starters. Second chuck the stock intake for something better like a trickflow or holley systemax, get 24 lb injectors with calibrated mass air. With a 331 and twisted wedge heads that motor is starving with your current induction.
310stanger said:
bump up the timing when it starts to ping jus a lil bump it back till it stops...
^ Don't do that. More timing doesn't necessarily mean more power and pinging could lead to replacing headgaskets. I've had base timing as high as 18° with no pinging on 93 octane, but I doubt my engine was making optimum power with that much timing.
Holley systemax ll, TFS-R intake, SVO 24lbers, 70mm Accufab TB, 73mm C & L MAF, custom burned chip. the stock computer still thinks there is a 302 there and will not compensate for increase in cubic inches or in A/F ratio. U run the risk of being too rich which washes out the rings and glazes the cylinder walls, or running too lean, pinging and detonation.
