The cam requires springs with 130-135# spring pressure, but stock TW heads are 110. Can anyone recomend a good valve spring for that range?
Also I just went to check my piston to valve clearance. I used play dough wich sucks cause it won't stick to the piston. I tried this twice, and with the head gasket in my clearance was only 0.05". Now I find it hard to believe that Ed C would grind the wrong cam for me. Could there be something here that I'm missing or possibly screwed up on?
I'm using the Fel-pro head gaskets recomended by Trick Flow, Trick Flow 6.75" pushrods (recomended) and pro magnum 1.6 rockers.
Any help or ideas would be greatly appreciated.
