  • SN95 4.6L Mustang Tech
Help with my Predator tunner
  • Thread starter Thread starter Cantslowdown
  • Start date Start date Mar 24, 2006
Cantslowdown
502
Mt.Home AR!
Mar 24, 2006
  • Mar 24, 2006
Ok i just got this thang and i dont have 93 octane in there and i have no clue like what rpm i want my shift points at and then the shift frims i am lost there too..Thats all i want to change right now whats the best settings for this..Later on tonight it will have 93 and then what will i need to change very lost here! Thanks everyone
Cantslowdown
502
Mt.Home AR!
Mar 24, 2006
  • Mar 24, 2006
Guys i really need help cuz i want to play with it tonight...And any other info will be good too..
propellerhead
1,541
"but what's with the but shots?"
Mar 25, 2006
  • Mar 25, 2006
I set my WOT shift points at the track. I set them so it shifts about half a second after the nose starts to fall. I got my best ETs that way. It ended up being something like 5750 to go into 2nd, then 5700 for going into 3rd and 4th.
Shift firmness is a personal thing. I settled on something like 35, 25, 10. Anything higher than that was too jerky. Anything lower was kinda soft. These may or may not be what you like. The beauty of it is you can change it as many times as needed to get the setting that are best for you.
'03GTinFLA
486
St. Petersburg, FL
Mar 26, 2006
  • Mar 26, 2006
When you get that 93 octane go ahead and change the timing. Check out the larger thread on that subject. SOTP gains.
Cobra Kai
9
  • Mar 26, 2006
The timing increase is at WOT only as a sidenote. FWIW, I have it maxed out at +10% in both ranges. It's nice.
loosescrew79
313
  • Mar 26, 2006
I actually run my timing advanced as far as it will go and I can still run 89 octane. Even with 89 no ping. Runs like a champ.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
  • Gulftown980x
  • Jul 29, 2026
squeak93
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
