Having a problem getting my 2.3 to run in my 87 mustang. The engine was rebuilt by a friend, a new head from Ford was put on when the engine was rebuilt. The engine is installed in the car, as far as I can tell all of the wiring is installed correctly. For some reason, I cannot get this damn thing to run. It has spark, compression, fuel pressure is good, I checked the injectors, timing is good, it has a new coil. Is there something critical in the wiring that would mess up the computer to the point it would not run? I am going to disconnect the fuel pump relay and see if it will run on just starting fluid. Right now, it won't run too well on starting fluid because it is getting so much fuel when we try to start it. Maybe the fuel regulator is bad? Anyone with ideas please share?
Thanks
Thanks
