Help with new disk brake setup
  • Thread starter Thread starter TC00GT
  • Start date Start date Sep 9, 2006
T
TC00GT
104
Auburn, Ma
Sep 9, 2006
  • Sep 9, 2006
I currently have my 66 289 coupe torn apart (from the doors forward). I am basically replacing the entire front end. What I have planned is a grab-a-trak syspension kit (1" drop) and I'm still on the fence about the shelby drop. The car is mostly going to be weekend driving, maybe a little agressive, but it won't see a track or 1/4 mile.
I've purchased the stuff I need for a granada swap, but all the posts here about the bump steer issues has me concerned. I am on somewhat of a budget, But more concerned with stopping.
I'd like some suggestions for brake kits, Some say Granada is ok, Scarebird? Wildwood or Baer (overpriced?)
Just curious what would work best with my planned set-up. Oh, manual steering also. Hope someone can help. Thanks.
5.0ina66
664
Ohio
Sep 9, 2006
  • Sep 9, 2006
Here are my thoughts (just wrote this for my website):
When I began looking at front discs, a lot of possibilities came up, namely: the Grandada swap, SSBC, Baer, Wilwood, Rod & Custom, Master Power Brakes, and Scarebird Mechanical.
The Granada swap can create suspension geometry problems in 65-66 Mustangs, and is incompatible with some performance control arms, which led me to conclude that I wanted a kit that used the stock spindles. Not to mention that Granada parts are on the expensive side, and the cost of finding the initial parts is now insane. Heck, back when you could get the stuff for $100, you were looking at $400 to refurb it with all new parts.
The ~$1000 cost of the SSBC kit shot that down, MPB's kit was similarly priced (~$800), and their customer service reputedly bad, and $650 for the small Baer setup was still high for my taste. Then, along came the $540 Wilwood kit...that's more like it. But Wilwood kits change track width, require safety wiring of the bolts, and use some unique parts. I decided I wanted something I could buy replacement parts for at the local Autozone in Nowheresville, so there went most of the kits anyway.
Then, along came the Rod & Custom RC132 kit...$350, full kit, commonly available parts, even steel braided flex lines; what's not to like? Well, after a few months of trying to track down someone who would tell me more than they had it and liked it, I found out that trimming the steering stops was not only necessary, but it was in the instructions. But wait, the Scarebird kit offered at the time used the same components (as far as I could determine) and was a straight bolt-on. What gives? I'm not about to cut on my car if I don't HAVE to, so there goes that one.
So, I'm doing a budget front-disc conversion using brackets from Scarebird Mechanical. As of August, 2006, I was told that these were superseded by a different setup that fits in 14" wheels. I just want some fair sized brakes on the cheap and I never, ever intend to use 14s, so I got lucky. My drums and hardware are all new, as well as the bearings, I suspect, so that's one possible expense I'm spared. Fresh bearings, seals, and hardware run about $40 from Rockauto for all of it, so a sub-$400 cost is still possible with that included (but with the brackets discontinued, I somehow doubt anyone else could do this particular conversion in the future).
IMO if you could get Scarebird to sell you one of the 11" rotor/Chevy calipers, that's the way I'd go. IMO there current 10" rotor/Chevy caliper setup is too small for any sort of use/abuse driving, and I think I got lucky when I bought my 11" rotor setup from him.
T
TC00GT
104
Auburn, Ma
Sep 9, 2006
  • Sep 9, 2006
Thanks for the reply. The Scarebird kit, is that the one that uses parts from about 4 different cars? I'm not sure I'm fond of that idea either. How is this kit with modified suspension? Is bump steer still going to be an issue?
5.0ina66
664
Ohio
Sep 9, 2006
  • Sep 9, 2006
Yep that's the kit. Bumpsteer won't be any more of an issue than dead stock, since it uses the stock spindles. I've ridden in a very similar car with the basic eqivalent of these brakes, and a VERY agresssive driver, so they should be more than adequate, especially with good pads.
R
Rapid
297
Columbia, SC
Sep 10, 2006
  • Sep 10, 2006
I have the Rod and Custom kit on my 65, with the A-arm drop, and 14 in Torg Thrust wheels. I am pleased with the set-up. Trimming the steering stop has not changed anything about driving the car but the other changes have made a big difference.
T
TC00GT
104
Auburn, Ma
Sep 10, 2006
  • Sep 10, 2006
Thanks. I know there are hundreds of people here with upgraded disk brakes. What else are people running?
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
P
Rear disk brake caliper parking brake adjustment
  • parrotguy
  • Oct 23, 2025
1974 - 1978 Mustang II Talk & Tech Oct 24, 2025
2Blue2
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
