  • SN95 4.6L Mustang Tech
Help with P1311 code.
  • Thread starter Thread starter 98gtr
  • Start date Start date Dec 11, 2006
9
98gtr
14
  • Dec 11, 2006
My CEL came on a few weeks ago and is giving out this code. I don't understand what this means. I looked it up on the web and I'm getting opinions ranging from bad front 02 sensor to faulty MAF sensor, bad fuel pump, dirty injectors, etc. Can anybody help me out with this? My car idles normal except for slight seconds everynow and then. It seems like it wants to hesitate when its wet or raining sometimes nothing too bad though and doesnt quite have the take off speed at low rpms.
jstreet0204
939
Winston Salem, NC
Dec 11, 2006
  • Dec 11, 2006
You sure that is the code? I'm not finding a DTC in my references using 1311.
9
98gtr
14
  • Dec 11, 2006
Sorry about that, I meant P1131.
jstreet0204
939
Winston Salem, NC
Dec 11, 2006
  • Dec 11, 2006
If it is driving bad when it rains like that, it is more than likely the o2 sensor. It would be the front passenger side o2. You can test it to make sure by swapping the two front o2 sensors. If the code follows the o2 then the o2 is bad. If it doesn't follow the o2 I'd start checking injectors. I personally just go ahead and replace it if it is fairly old.
J
JimC
170
Duluth GA
Dec 11, 2006
  • Dec 11, 2006
P1131 - Lack of HO2S - 11 Switch, Sensor Indicates Lean
A HEGO sensor indicating lean at the end of a test is trying to correct for an over rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
Causes:
http://www.bullittarchive.com/WebHelp/help/mustangspecs/2001_Mustang_Specifications.htm
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Dec 11, 2006
  • Dec 11, 2006
P1131 - Lack of HO2S-11 Switch, Sensor Indicates Lean
first thing you need to do is read the long term + short term fuel trims for both banks and get the total fuel trims.
If you see something like
Longterm1.. 20 % + shortterm 1.. 10 percent then bank one has a total fuel trim of + 30 percent
then what you want to do is compare the total fuel trim on bank one to the total fuel trim on bank 2..
If bank 2 is normal ( total fuel trim under 12 percent either positive or negitive) then your concern could be a misfire, exhaust leak before the sensor or a bad sensor itself.
If bank 2 has a high total trim but has not set a code then I would lean more towards a bad MAF or vacumm leak.
9
98gtr
14
  • Dec 11, 2006
Can you get to it from under the hood or do you have to jack the car up?
jstreet0204
939
Winston Salem, NC
Dec 11, 2006
  • Dec 11, 2006
I have to get under the car to get them.
Mike97gt
it doe snot
10,633
Dec 11, 2006
  • Dec 11, 2006
it's most likely the sensor itself.. as Jstreet said I would just replace that sensor.
02s11 is the top 02 sensor on the passenger side right near where the mid pipe connects to the exhaust manifold.
If you have access to a real scan tool then you can look at live data and look at the stuff I pointed out.
  • Gulftown980x
  • Jul 29, 2026
squeak93
ECU help!
  • starkiller1134
  • Aug 16, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
L
Drivetrain 2000 GT High Idle - Pulling Out Hair - Help
  • lleonard1185
  • Jan 18, 2025
SN95 4.6L Mustang Tech Jun 4, 2025
Leo090
L
G
Sputtering/misfiring below 2500rpm
  • Godless
  • Sep 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2025
gkomo
