Help with problems on first startup after h/c
I've got a friend with a 92 GT that just got done putting y302 heads on with an e-cam...I got the timing relative and it fired up, but it doesn't idle and it sounds like either a really loud exhaust leak or metal pieces slapping each other. I don't think it's the exhaust leak because the same headers were used before with no problems...what could be happenning and what should we check for? By the way, I thought that it could be that the stock rockers weren't adjusted right and that with this combo, the pushrods may need to be a different length.
Only way to tell is measure, or atleast color in the valve tip with a sharpie, set up one set of rockers, turn the motor over and then check the wear pattern on the valve tip. it should be centered, and no wider then .080" if it is off center towards the header the PR is too long, if it is towards the intake they are too short. You also want to make sure the roller tip first moves towards the header side, then towards the intake. I assume these are ped mount so you can also play with the shims to get the preload correct.
