Help With VIPER Alarm
  • Thread starter Thread starter Supes
  • Start date Start date Jun 15, 2007
Supes
  • Jun 15, 2007
I just purchased my cobra and for some reason the FOB does not work with the alarm. I tried to learn it into the system but no luck on that. does anyone have any ideas? it's an older viper with the older 2 button remote. :Track:
Supes
  • Jun 15, 2007
I'd appreciate any help on this
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Jun 15, 2007
  • Jun 15, 2007
I used to install alarms but you gotta help me out .. what does FOB stand for?
TwoToneHatch
170
New Jersey
Jun 15, 2007
  • Jun 15, 2007
I think he means "Key Fob"
steadfastcrew
15
North Las Vegas
Jun 15, 2007
  • Jun 15, 2007
fob = fresh off (the) boat
or
fob = fresh over (the) border
no seriously.. hes talkin about the remote transmitter
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Jun 15, 2007
  • Jun 15, 2007
Thanks. In that case I would check two things first. One, make sure the batteries in the transmitter are good and second make sure the antenna on the brain unit is in a good spot. A lot of companies like the antenna to be grounded to a good metal surface of the vehicle so the entire body can act as the antenna. Also, most alarms will blink a certain number of times when you first put the key in the ignition and turn to the acc position. The number of times that the LED blinks = the number of remotes programmed for that brain. I would be curious if the brain you have is at it's maximum number before requiring to be all together reprogrammed.
J
89 mustang alarm install to lock and unlock
  • jk66
  • Apr 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2026
jk66
J
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
R
Interior and Upholstery How to remove seatbelt torx screw
  • Riley Barth
  • Jul 6, 2026
Fox 5.0 Mustang Tech Jul 13, 2026
R
Interior and Upholstery Interior roof adhesive removal HELP
  • Riley Barth
  • Jun 22, 2026
Fox 5.0 Mustang Tech Jun 23, 2026
Riley Barth
R
