Help!!!!!!!!!!!
ChrisMic
12
I installed new underdrive pulleys about a month ago, everything was fine, but now there is a constant squeek coming from the belt, i put some 3-1 oil on it, and it helped for the time being, but later when i went back and started the car after it was cool the noise reappeared. It does seem to go away a little bit after the car has been driven for about 10 min, any suggestions
did u replace belt when u put on pulleys? if not, that is the problem. most people develop a bad squeal shortly afterwards if the belt is not replaced also. if u did replace belt, u really shouldn't be putting anything like oil on it.
