well i punctured a small hole in one of my radiator cross tubes trying to force a clip on for the fan shroud. the hole is really small, like pin size i didnt even notice it until after i put everything back together and went to fill the car. i then had a puddle at the base of my feet. i filled the hole with some high-temp silicone, the red stuff that people sometimes use on their lower intake to sides of lifter valley instead of the cork.
think that this will do the trick? or do you think there will be too much pressure and force the "seal" that i made right out? i globbed it on there pretty good.
