Help!
projectstallion
17
so i changed the throttlebody gasket on my 90 5.0 lx and it started having a over heatin problem so i checked for a vaccumm leak and fixed that then checked the fluid in the rad. and that was ok i drove it again and it over heated again but the strange thing was the intake manifold was at a good temp and the bottom was red hot any ideas? water pump? :shrug:
Ummm... just a throttle body gasket change? Wierd, must be a coincidence.
How old is the thermostat? Is it eating coolant? May be waterpump, but replacing a T-stat and diagnosing a blown headgasket is much easier than replacing a water pump (note I said diagnosing, not replacing).
