  • 2.3L (N/A & Turbo) Tech
Help
  • Thread starter Thread starter SHO_OFF_95
  • Start date Start date Dec 1, 2006
SHO_OFF_95
  • Dec 1, 2006
is there any kit to change out that crapy modulator for a distributor cap?
the thing is giving me to many problems
Stinger
7,754
24
118
Basehor (Kansas City), KS
Dec 1, 2006
  • Dec 1, 2006
How about telling use what car, what year, what "crapy modulater", etc.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 1, 2006
  • Dec 1, 2006
^ +1
SHO_OFF_95
  • Dec 2, 2006
92 lx 2.3 auto i don't know what the modulator is called but it is the part that fires the back 4 plugs on those goofy 8 plug motors
65ShelbyClone
4,675
38
119
Dec 2, 2006
  • Dec 2, 2006
That is one of the coil packs on your engine. You'd have to change a fair number of things in order to go back to a distributor.
Stinger
7,754
24
118
Dec 2, 2006
  • Dec 2, 2006
Actually, each coil fires one bank of plugs (one coil for passenger side, one for driver side). I don't know what fires the back 4 plugs...
Sounds to me like he's probably referring to having a bad ignition module...which can just be replaced for 80-90 bux and it's fixed.
SHO_OFF_95
  • Dec 2, 2006
could you alaborate a little bit?
alls i know is as of right now my car is only running off the secondary plugs(oddly enough i still get 20-22MPG)
Stinger
7,754
24
118
Dec 2, 2006
  • Dec 2, 2006
There are no "secondary" plugs, they all fire on the compression stroke.
I assume your tach is reading half as high as it should as well (idles at ~450-500rpm)?
You need to check to see which plugs aren't firing...easiest way to do so is when the car is off, unplug the front coil (all the plug wires go to the coils). Unplug it where the wiring harness plugs into the front of the coil, not unplug each plug wire. See if it will still start. Now plug it back in and unplug the wiring harness from the rear coil (it's at the back of the rear coil). See if it starts again. If it starts both times but runs bad, it's the ignition module, if it won't start, it's one of the coils that's bad.
SHO_OFF_95
  • Dec 2, 2006
all i know is 4 out of the 8 pulgs fire 20Degrees retarded and those are the only 4 that fire i hav done a ton os spark test and anything you could thing of to find the problem
Stinger
7,754
24
118
Dec 3, 2006
#10
  • Dec 3, 2006
  • #10
Hmm...only things that control spark timing are the crank trigger and the ecu...
Have you scanned for codes to see what the computer says is wrong?
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
CAMTWO1070
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
70 Mach 1 with Fluctuating Speedometer below 40mph
  • 70 Mach
  • Oct 19, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 19, 2026
Realmongo
