Help
  • Thread starter Thread starter redneckjeff
  • Start date Start date Jun 3, 2007
R
redneckjeff
  • Jun 3, 2007
I have a 69 mach1 with a 351W and I cant get it to stop backfiring out of the carb. I've replaced plugs wires points checked and rechecked firing order and timing. It only seems to be runnung on 4 cylinders. checked compression and all are between 145 and 155 lbs Any advice would be greatly appreciated.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Jun 3, 2007
  • Jun 3, 2007
Have you had the distributor out recently? Could be off by a tooth. Or the timing is way off. The only other time I've had that problem is when I got condensation under the distributor cap.
69 Rustang
307
Orange County California
Jun 3, 2007
  • Jun 3, 2007
Do you know the history of this motor--could it have a cam with a 302 firing order? If the cam was ever swapped, that could be possible. Otherwise, the distributor off a tooth, timing chain jumped, or???
M
mbc1967
Great State of Texas
Jun 7, 2007
  • Jun 7, 2007
Was having the same problem, If you have a 69-78 351w you will need to run the 302 firing order 15426378
SoCalCruising
2,437
SoCal
Jun 7, 2007
  • Jun 7, 2007
Hopefully it's just timing or firing order, even though you have checked this, because it otherwise sounds like fuel reversion through valves that aren't sealing. They could be bent or ?.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Jun 7, 2007
  • Jun 7, 2007
Need is a strong word because ALL factory 351w motors from 69' to their demise in the late 90's used the 13726548 firing order. This same firing order was also used in the 5.0 motors from the 80's.
As was mentioned by a previous poster, it could be 15426378 IF someone swapped in a 302 cam.
M
mbc1967
Jun 7, 2007
  • Jun 7, 2007
I am not a pro when it comes to all this engine building, all I know about my 351w is that is what I have and when I ran the 13726548 firing order it did the same thing that his was doing and I was told by a very good engine builder that 351w did have two firing orders, so I went and changed the plug wires to 15426378 and it pered like a CAT! But who knows I just might have a 302 cam, it sounds like it.
bnickel
5,640
lubbock, texas
Jun 7, 2007
  • Jun 7, 2007
ALL 351's (W, C and M and also 400) had the 13726548 firing order originally. i'm sorry but your engine builder either doesn't WTF he's talking or he assumed that you might have a 302 cam and just explained it wrong. just FYI
dennis112
1,561
36
79
Jun 8, 2007
  • Jun 8, 2007
Not to bust your balls, but a good tech website does their best to separate facts from hearsay. We want to put out as correct information as is possible.
The correct firing order for a Factory 351w is and has always been 13726548. Need concrete proof? Go to the library and find the Automotive repair section. Open up any Automotive service manual that includes a 351w motor, and you will find only ONE firing order for 69's and up. I have yet to see one bone fide publisher list the 302 firing order as available or as an option for a factory 351w . . . . . . .
A quick web search should provide the same information:
http://wiki.answers.com/Q/How_do_you_find_the_firing_order_for_a_351_v8
As mentioned a 302 cam can be installed in a 351w and will work correctly, as long as the 302 firing order is used. Ford did not produce them this way.
Engine 1994 5.0 refuses to idle
  • FordFanatic1894
  • Jul 20, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 22, 2025
General karthief
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 10, 2026
gkomo
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
