help
  • Thread starter Thread starter jhr351
  • Start date Start date Oct 30, 2007
J
jhr351
9
massachusetts
Oct 30, 2007
  • Oct 30, 2007
i have an 88 mustang gt , 306 trickflow tw heads street heat intake , e303 cam , ngk plugs , 9mm wires , msd distributor , digital 6 box , hvc 2 coil , 1.6 rr , 30lb injectors , fuel regulator , 255lph pump , double roller timing chain , 75mm throttle body , 76mm maf , mini torques starter , bbk shorty headers , dei starter blanket , under drive pulleys , now that you know most of the mods , here is my problem , the car starts and runs fine , but once it gets up to operating temp and i turn it off it wont restart , i have an a9p ecu , what could be causeing this , ive run out of ideas so any help will be put to use
black87ttop
43
burlington,new jersey
Oct 30, 2007
  • Oct 30, 2007
Need more info, does it turn over? Does it just crank and crank? How lond do you have to wait till it restarts. How long after it reaches operating temp will it not start. If you drive it for a lil bit but dont get it too operatin temp does it still do this?
J
jhr351
9
massachusetts
Oct 30, 2007
  • Oct 30, 2007
it does turn over but wont start , it takes a good 20 minutes before i can start it again , if its not up to operating temp ,it will start , i can drive it , it doesnt stall or anything , but once i turn it off , i need to wait till it cools before i can restart it
D
DREAMZOFHIRPM
40
BROOOOOOOKLYNN
Oct 30, 2007
  • Oct 30, 2007
mine was doin same thing never firgured it out prob went away after alt. upgrade.. i dunno it was weird man i thought it was wud be my starter ..it wasnt....
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 30, 2007
  • Oct 30, 2007
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 26-Aug-2007 to add missing secondary ground on back of the engine.
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse link is blown.
H.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
J.) Computer
I.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
J
jhr351
9
massachusetts
Oct 31, 2007
  • Oct 31, 2007
i put an 80amp alt in it , it piss' me off , if i wasnt getting fuel an spark it would start when its cold , am i correct with that statement ??? so what would change when it gets hot ?????????
bullitstang1313
713
Indianapolis / Columbus, Indiana
Oct 31, 2007
  • Oct 31, 2007
Have you tried any of the things in JRichker's post above. That should lead you right where you need to go. As far as your last post, if you aren't getting fuel and spark then no it will not start. There are plenty of people on here that can help you diagnose the issue. But if you don't do any troubleshooting all we can suggest are issues that we have experienced.
J
jhr351
9
massachusetts
Nov 1, 2007
  • Nov 1, 2007
ive tested the spark and im getting plenty of it , as far as injectors firing , i havent checked those , but i would think they are firing cause the car does run, i have driven it , i have the "salt and pepper shakers" tucked behind the intake , should i try moveing them away from heat , could that be the problem ?
bullitstang1313
713
Nov 1, 2007
  • Nov 1, 2007
So even when the car doesn't want to start you have spark? Did you just check spark at the coil or at the spark plugs. You may have it at the coil but not at the plugs. Have you checked the fuel pressure when it happens? If you give it some throttle does it start?
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 1, 2007
#10
  • Nov 1, 2007
  • #10
is your fuel pressure bleeding off, try holding gas to the floor while cranking
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Engine Car runs great without spout, plug it in and it dumps fuel and dies within seconds
  • baileygruwell
  • Jun 19, 2022
5K
Fox 5.0 Mustang Tech Jul 10, 2022
General karthief
Engine Valvetrain help please!!
  • sams93gt
  • Jun 23, 2020
2K
Fox 5.0 Mustang Tech Jul 11, 2020
sams93gt
Engine Head gasket or what?
  • Foxbody1988
  • Jan 17, 2020
4K
Fox 5.0 Mustang Tech Jan 19, 2020
7991LXnSHO
R
Engine 1992 Mustang Hesitation/Cutting-Out
  • RTW0223
  • May 2, 2018
14K
Fox 5.0 Mustang Tech May 26, 2025
