Help
Sentinel01
My 88 GT has 24lbs injectors and a Pro-M MAF calibrated for 24lbs injectors but my car stumbles horribly when its first started after sitting over night. Once its warms up, its better but its surges just a tad at cruising speeds. I have a chip installed but nothing changed. Whats wrong?
What codes do you get? I know of one you should see off the top of my head.
Do you know if the ECT is calibrated at low temps?
What are the mods and why does it have a chip?
Good luck.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
