HELP!
  • Thread starter Thread starter Alexander98gt
  • Start date Start date May 16, 2010
A
Alexander98gt
11
Im from maine but i live in Cali. and about to mov
May 16, 2010
  • May 16, 2010
Ok so here it is, got an 81 fox, bought it with original 3.3 in it, JUNK. anyway i picked up a 302 out of an old 78 f100, bored it .030 and threw some stock e7's on it and some off the shelf edelbrock intake on it, also not a huge fan. 600 edelbrock 600 carb, msd 6al ignition, blaster 3 coil and 8.5 superconductor wires. well had the freeze plugs pop out when i was deployed cause my buddy decided to leave straight water in it and leave it outside in the NC winter, just cold enough to pop them i guess. needless to say when he ran it up before i got home he overheated it in a BAD way, talking like 290! picked up a parker funnel web intake, installed it and got water leaking out of all four corners of the intake-head mating surface, hello warped heads! picked up a set of e7's that are ported with from proform roller rockers on them hoping everything will match up good, got a heads up from my buddy who actually knows something about racing and told me that ill have to "turn up" the motor, guessing hes talking about running at a higher rpm, says im going to have to due to the longer intake runners. any truth to that? what am i looking at for a base tune idle? really trying to get this thing back together, kills me to see it sitting idle. im sure someone has a little advice! Thanks!
KamiKaziDK
555
Mesa, Az
May 16, 2010
  • May 16, 2010
Sorry...but what exactly is the question here? Aren't you just throwing the engine all back together and starting it up? Are you asking what the idle should be? Kinda confusing. That intake will want to run a higher RPM yes, but what size cam are you running in it? With good ported E7s you'll want to run a 460-520 lift cam and tune her up decently, you could get anywhere from 260 to 315 rwhp I would say, hard to give a good number not knowing compression, etc.
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
Help! Intake Manifold Gasket or Head Gasket?
  • foxbodyclark
  • Oct 4, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
95 Laser GT Ver
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
help me decide
  • shelby65cobra
  • Jun 24, 2023
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2023
shelby65cobra
