I will start to say I am not a mechanic. Besides basic tuneup or minor repairs I don't work on cars but understand mechanics and am technically minded.
So....... my 94 mustang 5.0 took a **** on the freeway. Seems it was a head gasket as it was pressurizing the cooling system and quit running. I removed the heads and took them to a machine shop. They magnafluxed, cleaned and machined the head to flat ( he said they were warped). All the original head parts were retained as they looked in very good condition (although the exhaust valves were ground). I put it all back together and no start...not even a reaction. For timing I had decided that picking any cylinder and finding TDC by sticking finger in plug hole until end of compession stroke by manually turning engine, then aligning distributor rotor to the plug wire going to that cylinder and verifying that that plug fires as the cylinder compresses. Should be in near time. I am pretty sure that made sense....right?? So any way, no start. But if I rotate the distributor @ 90 deg from my so called perfect timing it will start but very rough with constant throttle up to keep it running. When removing one of the heads I did spill a quite a bit of water into the exhaust, would this cause cat. convertor failure and subsequent problem? I'm obviously confused...any takers?
