- Oct 5, 2013
- 7
- 0
- 2
my 98 gt had been cutting out few times..thought it was a fuel prob..died on me going to work..luckily i work at a dealorship/toyota..im a lube tech.NOT a d1 tech but have some common knowledge..did a quick check to see if i was getting fuel..wasnt..put a new fuel pump in..turned out had a blown 20amp fuse..put a new one in today to make it till monday..started car several times was running fine.got off work as i was leaving turned on a/c car died..when it did this last time id turned on cruise..ive seen some posts with similiar issues..seems like i need to investigate the module under right fender well???? does anyone know if it controls all the above mentioned or is it sound like a dreaded short???? THAAAANXX!!!!!
