basically remove the upper radiator hose, then loosen the hose clamp on the small hose going to the water pump, remove the two housing bolts and it's off.
while your there, make sure your t-stat housing isn't overly corroded, make sure the mating surface is clean. i always use a skim coat of rtv on the housing it self and on the manifold, then use a gasket in between....
then when you get the new t-stat, just make sure the spring side is pointing to the intake manifold. i put the rtv on the t-stat housing, theres like a lip or a "seat" the thermostat sits in, this is very important it's in that seat when you bolt it up. so i rtv the housing, set thermostat in the seat, place the gasket on, then put a skim coat of rtv on the manifld itself, put the housing back up to manifold and bolt it on.
the hardest part is getting that freeking small molded hose back onto the t-stat housing....and keeping the thermostat from falling out of that little seat as you put it up to the manifold.....it's not that hard it just takes some messing with.
someone else may have some pics and other tips.....hope this helps some...
