HERE COMES A HEADACHE
bad87coupe
conneticut
HEY GUYS I NEED SOME HELP.MY CAR STARTED BUCKIN AND SOME POPPIN,AND IT WAS DETONATING. AT LOW RPM IT WAS BUCKIN SO I GAVE IT SOME GAS THEN IT WAS DETONATING AND SOME SMOKE LIKE IF YOU MISSED A GEAR SHIFTING.THE CAR HAS A VORTECH AND THE BASE TIMING HAS BEEN AT 8 FOR 2 YEARS. FUEL PUMP IS NEW,CAP,ROTOR,COIL,WIRES PLUGS,INJECTORS, THE CAR IS A 87 AND THE DISTRIBUTOR LOOKS ORIGINAL,SO I'M THINKIN THATS THE PROBLEM. I HOPE YOU CON GIVE ME SOME ADVISE. THANKS,ANTHONY
Your 87 wont have a functional CEL unless you wired it in.
Furthermore, codes can be stored even though the issue doesnt meet the criteria to light off a CEL (on cars so equipped), so it is always wise to retrieve the codes.
A quick and dirty test is to use electrical contact cleaner on the PIP components. The shudder can get dirty and cause issues. While in there, note how much dizzy main-shaft wobble you have. If excessive, that can cause PIP issues.
The blower and associated tune with it is another variable.
Good luck.
hissin.... my car was converted to maf before i got the car, i put a bulb in the CEL slot, and when i turn the key on it lights up with the low oil light, etc.
is that all it takes to wire it up? the computer is an 89 5 spd computer i believe, dont know if they had the cel in it, but it does light up so im wondering whether it will when its telling me theres a problem or not?
sorry to hijack teh thread0rzz
Euphoric, so now you have two low oil lights (there's one near the CEL and one in your GT 4 light cluster)?
There should have been no wiring to the CEL AFAIK (on factory SD cars). Maybe someone else will know why yours worked. :shrug:
