Here's the pics from my intake swap....
donkey_punch said:
sorry this is off topic. but is there any good tech threads about rerouting all the wires and lines to the inside of the fender? i would like to keep like the a/c, p/s ect. but also want to remove the cluster *** of all the wires and lines.
by the way, :nice: for doing the install yourself. cause everthing i touch goes to hell.
Try searching, I found all these and it only took 30 seconds :nice:
http://forums.stangnet.com/showthread.php?t=557785&highlight=wire+hiding
http://forums.stangnet.com/showthread.php?t=556186&highlight=wire+hiding
http://forums.stangnet.com/showthread.php?t=516492&highlight=wire+hiding
http://forums.stangnet.com/showthread.php?t=503022&highlight=wire+hiding
http://forums.stangnet.com/showthread.php?t=494767&highlight=wire+hiding
Did the same thing on my first 95 along with MAC LT's and Pro Chamber H pipe. I couldnt get the fuel lines unhooked w/that cheesy disconnect thing you puy at parts stores so I just left it connected. EGR tube to headers I just capped off. As for the overheating thing, you mihgt have an air pocket. I rushed the filling of the rad and it trapped some air in it. No biggy. Congrats.
legalize420gt95 said:
6 bolts on the upper. 2 are under the plaque
Haha! I was yank yank yankin on that thing, lol. Thanks much (damn torx screws)
Also, How did he get a trickflow in there without a larger hood? Every install I have seen requireds the big hood scoop! :shrug:
:scratch: The Trickflow (as well as Edelbrock and most other) intakes fit under the stock hood just fine. The problem comes in when you try and use a phenolic spacer between the upp and lower plenum.
If you have stock VC's everything will be fine if you have fox VC's you need a spacer then probably run into stock hood issues. I had an aftermarket hood on mine and still had problems cause of the way it was made. Then new hood is made different and everything fits fine
