Hesitating!!HELP
Did you dump the codes to eliminate any of those possibilities? There are too many variables to pin point your exact cause without that step.
(If you haven't done it, it's free and takes only 2 minutes) Search for the word codes and JRichker. He had the perfect write up
new set of o2 sensors? and tighten up the "salt and pepper shaker"(10 pin connectors) would be a good start. and if it dosent fix the problem it will def help in the long run anyways :) also check the TPS voltage try to get around .97ish
