  • SN95 V6 Mustang Tech
Hesitation help!!
  • Thread starter Thread starter proudponyowner
  • Start date Start date Jul 24, 2011
P
proudponyowner
  • Jul 24, 2011
I have a 2003 3.8L obviously lol but Im having some serious problems with hesitation during normal acceleration. I have some knowledge of cars but this is seriously giving me issues. I started to notice it hesitating from a stop light and then the engine light came on. I took it to autozone and had it scanned it came out as crankshaft position sensor fault and cylinder 1 misfire. So I replaced the plugs, wires, and the sensor. It's still giving me problems doing the exact same thing. What am I missing?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 25, 2011
  • Jul 25, 2011
Go back to the autoparts store and have the alternator tested for correct output and excessive AC ripple. A bad alternator diode will interfer with the cam sensor signal causing problems.
While there have the battery tested.
Are the battery cables clean, tight, and corrosion free?
When the plug wires were replaced, did you follow the factory routing and use all standoffs and looms? Are the plug wires touching any metal parts? Inspect the plug wires for white spots which indicate arcing.
Always post the full DTC codes. There are 1000's and they each have a story to tell. I suspect your DTC is a cam sensor problem and not a crank sensor (CKP). Most cars with CKP sensor issues won't run at all.
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 10, 2026
gkomo
D
SN95 V6 1994 occasional rpm surge while driving---where should I start?
  • DPP
  • Aug 30, 2025
SN95 V6 Mustang Tech May 5, 2026
DPP
D
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
C
1997 3.8l v6 timing cover mismatch *eBay guaranteed fit* haha please HELP
  • chasondragons
  • Apr 3, 2026
SN95 V6 Mustang Tech Apr 3, 2026
chasondragons
C
