Hesitation/Loss power/Bucking Help!!
155dB5.0
165
Upper MI
Ok so im not quit sure how to fix this one yet. Car is hesitating in the lower rpm's like 0-3k. It also is bucking at low speeds and dosent even feel as strong up top as it used to. Before i could pop the clutch at 2-3k and spin em through first and most of 2nd now its just sad. Before the basics come up, this is what i have done for my tune up this year
New:
Plugs gapped to .60 for screaming daemon
cap and router
fuel filter
pvc
FP set at about 39-40 with vacume off
14 degrees timing
Plug wires were not changed cause the are Live wires and i think they are suposed to last a while.
I have read it could be the PIP sensor or the O2's, Fuel pump, just looking for some more ideas and input.
Thanks
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
See the "Surging Idle Checklist for help with all your idle/stall problems before you make any idle adjustments.
The quick and easy way to dump the codes is in there too, and all you need to do it is a paper clip! The first two posts contain all the fixes & updates. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
New o2's are in, it does seem to be running better. The old ones were black as hell and im sure the car is running rich but im not sure why..... Next im going to replace the ACT and ECT for good measure and a new distributor this winter. Still some surge when hot but nothing to annoying
