  • SN95 4.6L Mustang Tech
hesitation
  • Thread starter Thread starter 98COBRA281
  • Start date Start date Jan 30, 2008
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Jan 30, 2008
  • Jan 30, 2008
i just did the intake swap on my car over the weekend, it was running great but i had a small coolant leek so i removed it again to fix the leak i got it all back to gather and took it for a ride now when i step on the gas in any gear it will hesatate a little then got away but as the rpm get higher it does it more, i have checked all the sensory 3 times and have no clue what it is
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jan 30, 2008
  • Jan 30, 2008
Check the plugs and wires. You may have gotten some coolant in in the plug wells and may be causing the problem.
O
ottos
  • Jan 31, 2008
Exact same situation as I had in my 99 GT. Swapped to the new Al intake, then misfire city. Got the newest PCM calibration from Ford dealer $80 and its solved. Initially it still bogged after the reflash, but computer relearned its program in a few miles and viola... fixed!
Or you can try driving it around more and see if it clears up as the PCM re-learns the fuel trim.
M
MichaelsLilGray
32
Tyler, Texas
Feb 1, 2008
  • Feb 1, 2008
couple of pausable issues...ECM needs to relearn the new configuation, depending on how much you drove it... you could have got coolant on the plugs, or for that matter had some drop threw the intake.. and get into the engine.. thats always fun.. Check for leans in your vac lines.. also any gaskets leading from the Air intake to the intake manifold... after a week your recommended to go back threw and check tourqe on your manifold anyways...
98COBRA281
1,348
30
59
Feb 1, 2008
  • Feb 1, 2008
i went and rechecked everthing and i happened to find the spark plug wire right under the intake on the passenger side was pulled off just a tad bit pluged it back on and it cleared right up
Smokeurhonda
457
Maryland
Feb 1, 2008
  • Feb 1, 2008
bueno
M
MichaelsLilGray
32
Tyler, Texas
Feb 2, 2008
  • Feb 2, 2008
Glad it worked out for you
P
Electrical 2001 GT Overcharging
  • PseudoGT
  • Dec 3, 2025
SN95 4.6L Mustang Tech Dec 13, 2025
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 30, 2026
badmech
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
