When the key is off and i turn the headlights on, the high beams, low beams and flash to pass all work. But the high beam indicator does not come on... When the key is in the on position the high beam indicator stays on weather the lights are on or off. NOW MY QUESTION IS WHAT IS CAUSING THE HIGH BEAM INDICATOR TO STAY ON??? The engine and trans have been pulled and put back in for a stroker swap. When the trans was pulled I forgot to disconnect all the wires from it. other than that no other work has been done resently. One thought i had was maybe a problem with the low oil level sensor since it runs on the same fuse.
