high flow oil pump
dave 1970
49
can anyone tell me what the advantage is of using a high flow oil pump,i see know advantage except for blowing out an oil filter,the motor has a high volume on it mow i think i will change back to stock,if no one knows of any advantage,thankyou for your in put
Unless your engine was built with a high flow pump in mind (looser bearing tollerance, more oiling ports, etc) there is no benifit.
In fact you run a higher risk of shaft or dist gear failure which could cause more damage in the end.
A high volume, not high pressure , pump is designed to flow more oil at the same given r.p.m. This is useful in racing situations where the bearing clearance are set to a looser tolerance. For a street engine, (or even alot of dual purpose emgines), the clearance are set tighter; so a high volume serves no purpose other than to damage the oil filter or press-in oil plugs.
A word of caution on stock pumps though; they are net checked very well for tolerances and you can get a crappy one. A blueprinted stock pump is a good idea. Someone will chime in and say that they've used hundreds of stock pumps with no problem, but it only take one out-of-whack pump to destroy an engine that cost you thousands of dollars to build, so it should be considered.
High volume pump is for loose bearings.
The extra stress on a street engine is focused on the oil drive shaft, cam gear, and distributor shaft.
Not a good thing for a streeter.
Believe it or not, the HV pump also has a high parasitic HP loss.
Dave
http://data.melling.com/Tech pdfs/HIGHVOLUMEPUMPS.pdf
The hv pumps only flow 20-25% more than a standard pump. The difference in hp loss is like going from 10-30w to 20-50w oil, maybe a few hp. I have one in my engine and my bearing clearances were within range. My gauge goes about 3/4 when cold then to the half mark warm and idling. I don't like the huge main bearings in a 351w plus rpms is the reason why is stuck it in there. I also have a 8 quart pan.
Dammit, I just ordered a HV pump from Summit. Should I send it back for a Standard volume pump? I lost a cam lobe last year, and the oil pump is the only part in the engine not protected by the filter right? So I thought I'd just get a HV pump while I was at it. Bad idea? I still have my old SV pump.
This is the pump I ordered:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SLP%2D224%2D41143V&N=700+0&autoview=sku
Don't send it back...
It's not that big a deal.
I have one in my very mild 302.
Would I take it out or lose sleep?
No.
If I swap it again, will I use HV?
Probably not, but it's not a big deal.
It's not often that these negatives actually rear their heads.
Dave
No.
Dave
thankyou all for the input,i ordered a heavy duty pump shaft from for ,i will stay with the stock pump,thanks again
oil pump reply
hello ,right now i am running casteroil syntec 10w-30 i also relocated the oil filter in the grill with an oil cooler,seems to work fine,the motor im building to put in i also cut out the bottom pan to make room for more oil,going to cut the pan off of a duetz diesel and weld it on the bottom of a stock front sump pan
