  • SN95 4.6L Mustang Tech
Engine High Idle 2002 Gt
  • Thread starter Thread starter Rello
  • Start date Start date Aug 13, 2015
R
Rello
  • Aug 13, 2015
So I have a 2002 GT(roush stage 1if it makes a difference) and recently I have had a code P0401 for egr come up. It then Started to idle anywhere from 1500 to 2000rpm at times. It only idled high after warming up. It's not a rough idle it gets there and it sticks. It's so bad that the car could drive itself in second car and sometimes 3rd when idling at 2000. I checked for leaks found none so I flashed the ecu and reinstalled the custom tune. It ran fine for 2 days then started to idle high again but the code never came back. Has anybody had this problem or can anybody help me out?
J
jeno_labanca
109
Aug 13, 2015
  • Aug 13, 2015
Well since you got the code for the egr clean it or better yet do the egr delete since you have a tuner but you need the delete kit
Sent from my Nexus 6 using Tapatalk
trinity_gt
3,125
81
99
Canada
Aug 13, 2015
  • Aug 13, 2015
I'd start with the IAC valve for the idle speed issue.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Aug 20, 2015
  • Aug 20, 2015
Consider ruling out a vacuum leak before replacing parts.
Here's some more information:
Troubleshoot IAC idle problems 1996-2004
Troubleshoot IAC idle problems 1996-2004 | Mustang Forums at StangNet
TeamCaffeineGT
193
15
18
Springfield, MO
Aug 20, 2015
  • Aug 20, 2015
+1 on the IAC. This is pretty common. They will either idle high, or cause low idle/stall problems when they are on the outs. I would advise avoiding non-genuine replacements if the IAC has to be replaced. I went through 2 defective out of the box IACs from O'Reilys before I went to Ford. Best Luck!
SteveJessica
  • Aug 20, 2015
Check your tpc or iac
Hardtop68
193
Wherever they need me
Aug 23, 2015
  • Aug 23, 2015
Mine had high idle before due to the alternator's diode bridge failure. This also produced a hissing sound from the alternator that may be mistaken as a bearing problem.
R
Rello
  • Aug 30, 2015
So just a update. I decided to clean the TB, IAC, and EGR. Since then I have had no problem at all and that was back on Aug 15th.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Aug 30, 2015
  • Aug 30, 2015
Score +1 for starting with the basics!!!
Reactions: Rello
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
2003 GT High Idle, vac leak process
  • krysber
  • May 11, 2025
SN95 4.6L Mustang Tech May 11, 2025
krysber
K
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
