High idle after timing advance
  • Thread starter Thread starter ebk06
  • Start date Start date Jul 7, 2007
E
ebk06
113
12
18
Jul 7, 2007
  • Jul 7, 2007
I adjusted my timing to about 13*-14* and now my idle stays around 1300-1500 rpms. Car runs fine no problems at all just a high idle. My setup is basically stock and my car is an '87 with speed dentsity. Anyone got any hints what it could be?
thanks
Marcus
cenok is family
1,409
69
79
Norman, Ok
Jul 7, 2007
  • Jul 7, 2007
thanks
Marcus
when you advance your timing, your idle advances as well. just turn it down at the throttle body.
E
ebk06
113
12
18
Jul 7, 2007
  • Jul 7, 2007
yea i tried doing it with the idle adjustment screw but it was backout as much as possible already. Im guessing you know somewhere else there is an adjustment at, hopefully? wanna share with a newbie? lol
cenok is family
1,409
69
79
Norman, Ok
Jul 7, 2007
  • Jul 7, 2007
what's your tps voltage?
HISSIN50
34
129
Jul 8, 2007
  • Jul 8, 2007
I'd look for a small vac leak or an issue with the IAC.
I'd pull the codes and then clear the KAM and see what it does.
Good luck.
E
ebk06
113
12
18
Jul 8, 2007
  • Jul 8, 2007
Whats the KAM? I just had the car at the shop for vacuum leaks and a new IAC was installed all less the 600 miles ago and nothing was wrong with the idle before i adjusted the timing.
E
ebk06
113
12
18
Jul 8, 2007
  • Jul 8, 2007
Ill check the TPS voltage tomorrow. I do know it was replaced at least a couple thousand miles ago beforei bought the car.......and i have the receipt showing me proof.
HISSIN50
34
129
Jul 8, 2007
  • Jul 8, 2007
KAM = Keep Alive Memory. It's the puter's recollection of how it has adapted to accomodate issues with your car. Clearning it (disconnect the battery and turn on the headlights for 10 seconds to discharge the capacitors) can sometimes help. If your car had gone to some extreme adaptive parameter, it would take awhile to relearn where it should be. You will be starting off with a stock, unmodified baseline instead.
vristang
4,933
101
124
Seattle
Jul 8, 2007
  • Jul 8, 2007
TPS should CAUSE high idle...
Clear the KAM
and
REset base idle and see what it does...
http://www.muscularmustangs.com/idlereset.php
jason
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 8, 2007
#10
  • Jul 8, 2007
  • #10
See "Surging Idle Checklist for help with all your idle/stall problems. The first two posts contain all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
E
ebk06
113
12
18
Jul 8, 2007
#11
  • Jul 8, 2007
  • #11
well i guess i will just take it back to the shop. the TPS voltage was .90 (measured with a Fluke), i did a KAM reset and still high idle. The IAC, ECT, ACT, PCV, EGR, EGR Sensor all have less than 600 miles on them. Maybe one of the sensors is defective in which case should still be under warranty from the shop. If anyone may have any other ideas please let me know.
E
ebk06
113
12
18
Jul 8, 2007
#12
  • Jul 8, 2007
  • #12
anyone have experience with a code 82? I thinks its a solenoid for the smog pump. My 87 302 has the smog pump deleted and the high idle wasnt an issue before my timing adjustment.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
D
Engine Throttle sticky even after cable replacement
  • dqureshi06
  • Aug 16, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
