High idling when in neutral fully warmed up
  • Thread starter Thread starter Mercedez
  • Start date Start date Dec 4, 2008
  • 3
First Prev 2 of 3 Next Last
hotcobra03
poteet,tx
Dec 7, 2008
#21
  • Dec 7, 2008
  • #21
Been waiting on answer about codes.my first thought was act but u say is new. Iac was only cleaned .with no codes im leaning to egr valve sticking.but also tb linkage .when metal heats it expands and thats when your problem acures .most tb problems will spit code but egr wont
hotcobra03
poteet,tx
Dec 7, 2008
#22
  • Dec 7, 2008
  • #22
Your egr valve might be the hotist part next to exhaust manifold
D
drpgtcoupe
12
suches ga
Dec 7, 2008
#23
  • Dec 7, 2008
  • #23
i agree with the cobra dude check ur egr espically if u dont have a light comeing on. u may also have a small air leak some where too.
HISSIN50
34
129
Dec 7, 2008
#24
  • Dec 7, 2008
  • #24
EGR flow at idle will cause the engine to stall, not idle higher.
Mercedez
36
San Francisco
Dec 7, 2008
#25
  • Dec 7, 2008
  • #25
I HAD BATTERY DISCONNECTED AND THEN CONNECTED AGAIN.
dcurtis
688
Dec 8, 2008
#26
  • Dec 8, 2008
  • #26
Thats what I was thinking, have you checked the tps or no, I have another car and when I start it, it idles fine after a while the idle will climb to about 2000rpms or so and stay there, I can shut it off, unplug the tps and when I start it back it idles just fine, I know the tps is my problem I just havn't replaced it yet, may not be your problem but the symptoms sound similar, good luck
Mercedez
36
San Francisco
Dec 8, 2008
#27
  • Dec 8, 2008
  • #27
I'm not sure on that and I thnk the TPS was replaced before.
D
drpgtcoupe
12
suches ga
Dec 8, 2008
#28
  • Dec 8, 2008
  • #28
yeah if its stopped up it would try to stall. but if small a peace of trash or somethin went threw and stuck the egr valve open it would act just like a vacume leak. and if more and more trash comes in and strats blocking it off it would start stalling it out
D
drpgtcoupe
12
suches ga
Dec 8, 2008
#29
  • Dec 8, 2008
  • #29
my bad posted same thing twice
Mercedez
36
San Francisco
Dec 8, 2008
#30
  • Dec 8, 2008
  • #30
:fairyfight::stirpot:
:fairyfight:
Choose your form of punishment.
HISSIN50
34
129
Dec 8, 2008
#31
  • Dec 8, 2008
  • #31
Due to the properties of inert gasses, this is not something I've experienced. I'm not sure that others have either.
And you're talking about two different issues. An EGR valve that's stuck open causes stalling due to the dilution. EGR passages that are clogged or coked cause part throttle pinging and seldom cause idle issues (because EGR gasses cant make it back to the intake anyhow).
backfocus
254
Little Rock, AR
Dec 8, 2008
#32
  • Dec 8, 2008
  • #32
1. Have you checked codes yet? Just because the light isn't on doesn't mean there are no codes, check both Engine off and Engine on.
2. Have you went through the list I referenced?
I don't want to just guess, because then you might be throwing parts at a problem and not fixing it. It could still be a number of things, TPS, vacuum leak, etc.
Check the codes first, then the list and if everything passes, it could just be a base idle reset. But you won't know unless other items are addressed first. I know the list refers to surging idle, but those checks will help narrow down the problem, as many issues are tied to the same pieces as to what could be causing your problem.
At lastly what rpm does your car run at on cold warm-up? On average.
Mercedez
36
San Francisco
Dec 8, 2008
#33
  • Dec 8, 2008
  • #33
But it does run at 800 RPM normally.
D
drpgtcoupe
12
suches ga
Dec 9, 2008
#34
  • Dec 9, 2008
  • #34
read this
Ford Fuel Injection EGR Vacuum Regulator (EVR)
this just clearly stated that the rpms would change. weather its clogged or not if its not working
this is off another site different car same princ.
EGR Valve / Solenoid - Tech / General Engine - Third Generation F-Body Message Boards
regardless this is not her problem i did some research.
HISSIN50
34
129
Dec 9, 2008
#35
  • Dec 9, 2008
  • #35
drpgtcoupe said:
read this
I'm well aware of the theory and practical application of the EGR system. I saw nothing that refuted what I already stated. In the FFI article, the idle would degrade if doing their test.
And I'm not sure what the point of the third Gen link was.
Some posts ago, I mentioned that the symptoms didn't support an EGR issue.
hotcobra03
poteet,tx
Dec 10, 2008
#36
  • Dec 10, 2008
  • #36
My wheels are still in motion on this.im waiting to see if his lite comes on.what ive read today about your views on iac cleaning was interesting. Binding linkage and iac ?
Mercedez
36
San Francisco
Dec 10, 2008
#37
  • Dec 10, 2008
  • #37
I had IAC cleaned and throttle body and it didn't have any affect.
backfocus
254
Little Rock, AR
Dec 10, 2008
#38
  • Dec 10, 2008
  • #38
Unless I missed something, she still has not checked the codes, so until then we are just guessing.
The IAC was only cleaned. I have had problems with my car in the past, all be it surging idle, that I cleaned the IAC very well twice and had no effect. Replaced the IAC and problem fixed, of course after a computer reset.
It still could be a number of things, so I am not venturing out with a guess untill the codes answer comes back.
Mercedez
36
San Francisco
Dec 11, 2008
#39
  • Dec 11, 2008
  • #39
I'll have a mechanic check it out. I don't have that kind of equipment and tools.
backfocus
254
Little Rock, AR
Dec 11, 2008
#40
  • Dec 11, 2008
  • #40
Just take it to you local "trusted" auto parts store, most will check the codes for free, or you could buy a code reader for about 30 dollars. When owning these cars, they due come in very handy.
  • 3
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
C
Engine Code 13 and high idle
  • CmdrDerp
  • Dec 14, 2024
Fox 5.0 Mustang Tech Dec 21, 2024
manicmechanic007
