  • 1994 - 1995 Specific Tech
high volume oil pump?
  • Thread starter Thread starter oosmytoo
  • Start date Start date May 11, 2004
O
oosmytoo
530
Portland - Oregon
May 11, 2004
  • May 11, 2004
cars going to the shop to get a new oil pan gasket, while its in there its also having the bassani headers and O/R x pipe installed. my question is, while the pan is off, should i go ahead and put a high volume oil pump in there, or just put a stock replacement. i dont plan on taking the pan off any time after. thanks guys!
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
May 11, 2004
  • May 11, 2004
I say do it while it's open that is always an awsome upgrade it will give the engine more longevity which is always a good thing. just my .02
67stang390
379
Seattle, WA(home) ASU(college)
May 12, 2004
  • May 12, 2004
NO! You don't have a higher displacement engine or any reason for a higher volume oil pump. It will move oil around faster, but that isn't neccessarily a good thing when you don't have a need for it. If your stock oil pump works fine, then please just keep it. You will crap a brick when your "brand new" high volume oil pump decides to retire early for no apparent reason. One of the best things my dad ever told me about cars was that "if it works now, it will probably work in the future. If it's brand new, who knows when it will work."
D
dirtyo2000
31
  • May 12, 2004
well you can replace it if you like nothing wrong with that. but dont go high volume with a stock pan because it does just what it says pumps a high volume of oil. all motors love to be drowned in oil for long life but the problem is with a stock pan the oil pump can actually pump all the oil out under high rpms thus not having the oil return fast enough you end up having no oil at all sometimes. i would leave it stock unless your changing the pan. most people that run after market oil pumps wheter it be high volume or pressure run larger oil pans
moneypit94
1,723
Macomb, IL
May 12, 2004
  • May 12, 2004
dirtyo2000 said exactly what i was going to say... I am running a high volume oil pump but im also running a canton oil pan...
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
351w aluminum oil pump?
  • Kid wita 5oh
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
Mustang5L5
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
