hm....valves...questions....
rednotch88
151
CHICAGO
E7 heads....whats the largest valves I can stuff in them?What size is the valve stem? I heard you can run Chevrolet valves..?Cheaper? :shrug: What is the combustion chamber size?I know these question have probably been asked a ton of times,but I couldn't really find what I needed while searching.
Thanks,
KJ
I am not familiar with the heads but a few thoughts. When ever you can use Chevy parts go for it they are always cheaper. 11/32 stems are a good size for most performance applications that I am familiar with. Last don’t get to caught up on bigger valves, that don’t mean they will flow more air. There is a ratio between port area and valve dia. and many more factors. I just finished reworking my AFR 185 heads that the previous owner put 2.05in and 1.6ex. It did not help it, I have a friend that has a flow bench and tried all kinds of stuff (bowl/valve job/back cut on valve) started with 155cfm at .6 lift ended up with 165cfm. Even with the valve all the way open like 1.0" lift the head only flowed 170cfm. The port was just not big enough or the 4" bore was to small and shrouded the valve too. Also note that AFR claims more air flow and also are a 185cc intake port not these they only came out to 175cc.
Scott
