Hole in piston?
rrudholm
60
What are the symtoms of a hole in a piston. There is no smoke but it kinda sounds like its not runing on all cylinders and there is a lot of valvetrain clicking noise. I adjusted the roller rockers but it still sounds the same.
Do a compression check. Hole in piston = no compression. This is what I would do first. This can also indicate other issues, like a valve that is not closing all the way, or blown headgasket...
You could also do a KOER cylinder balance test.
Rick
Thanks, I think this whole problem is a valve train problem.
I will do a compression test first before anything. I did however pull the number 3 intake rocker off as it was lose and seen signs that the pushrod made some gouges in the rockers . I hope the cam is not damaged. I had a local machine shop build this engine but I'm not too happy with them at this point.
