Holley 750
  • Thread starter Thread starter MACH1MUSTANG
  • Start date Start date Jan 29, 2007
M
MACH1MUSTANG
28
Missouri
Jan 29, 2007
  • Jan 29, 2007
What is the correct way to tune a car when you are trying to set the timing and fuel / air mixture? Which do you do first? Where is a good starting point with the mixture screws and what is the minimum they should be turned open? These questions are for a 1969 351W. I will probably not be using vac. adv. since I am looking for HP not gas milage.
bnickel
5,640
lubbock, texas
Jan 29, 2007
  • Jan 29, 2007
i always set the timing first, then set the idle speed and idle mixture using a vacuum gauge to get the highest vacuum reading then fine tune the idle from there until by ear. i usually set the timing with a combination of vacuum, timing light and by ear until i have it just right. i can tell you already you are going to get a bunch of different answers because everyone does it a little differently.
fvike
335
Mosjøen, Norway
Jan 29, 2007
  • Jan 29, 2007
Before any carburetor tuning, the fuel bowl float level must be correct. If it's not, it might sound and look good on idle, but will pop or backfire when driving.
D
D.Hearne
11,730
south louisiana
Jan 29, 2007
  • Jan 29, 2007
Starting point for the idle mixture screws ( these are on either side of the main metering block) is usually 1-1/2 turns. And don't think these are more than idle screws. They have nothing to do with the mixture once the carb has transitioned to the main circuit. The main jets (and secondary jets if it's a 4150) control the mixture once the engine's off idle. (in addition to the powervalve and air bleeds.) To figure what's the best fuel/air mix you either must use a Fuel/Air meter or learn to read the spark plugs. The meter is more precise and faster, but it cost's you nothing to read the plugs other than labor.
H
Holley Carb Tuning Help
  • hassler
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 29, 2025
85GTStangGuy
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Tips for WUE and ASE tuning
  • Mustang5L5
  • Oct 9, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 10, 2025
gkomo
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
