I have a 3310 Holley carb and had 2 questions as I'm rebuilding it.
question 1: I tried using a rubber mallet to get the primary metering block loose to no avail. is there a screw that I am missing or some trick to getting this loose.
question 2: on the secondary metering block there are these funky screws that have an oblong hole in them. first I assume I need to remove these to get the secondary metering block off or am I wrong? what do I use to get them out if I need to? I have to replace the gasket.
thanks for any help!
You might bleach the body but I'd rather have one that works than a good looking carb that doesn't
The gallon size can of soaking cleaner will usually accomodate the main body with the meteing block attached, just not the whole thing submerged
