ok i have:
302
9:5:1 compression
forged pistons
trick flow 202 heads
Weiand X intake
Mild cam (cant really remember specs.. 513 lift.. with ??? duration
4:11 gears
t-5z tranny
msd 6a ignition box
msd boost timming master
running base timming 14
distributor locked at 32 max timming
boost timming box retarded down to 23 degrees max timming
Holley blow thru carb (750 by carb shop)
paxton boost ref fuel pump (for now going electrical in a few months)
Paxton novi 1200 with 7-8 pounds of boost (for now 14 when new fuel pump gets on)
shorty headers with 2-1/2" exhaust dumped at axle
carb shop blow thur carb....
750 double pumper
31 squirters 31 squirter in rear 30cc accl
72 front jets
78 rear
4.5 power valv
now for my problem area:
from a dead stop i really dont have any sputter in the carb, but when im crusing and stab the gas it falls on its face and then takes off. I have been playing with the acclerator pump & nozzles. Now my question is i have 31 squirters in the front and rear should i up grade to the next size in the rear or front? My pump cams are set in the first hole and are pink.
thanks
302
9:5:1 compression
forged pistons
Weiand X intake
4:11 gears
t-5z tranny
msd 6a ignition box
750 double pumper
72 front jets
78 rear
4.5 power valv
thanks
