Holley Mods
  • Thread starter Thread starter woodsnake
  • Start date Start date Jan 3, 2009
woodsnake
1,352
15
69
Hicksville, NY
Jan 3, 2009
  • Jan 3, 2009
When people get the air horn milled down, who does the work? Just any old machine shop, or does it have to be a specialist? I bought a 3310 Holley, that the PO tried to remove the air horn on, and broke the 'back' of the primary 'wall' for lack of a better way to describe it. I've seen a lot of carbs that have had the barrier between the front and rear venturies removed. I just don't know who to talk to about getting it done?
R
ron67fb
1,117
SF Bay area, CA
Jan 4, 2009
  • Jan 4, 2009
I did it on a manual mill in a city college machine shop night class. We also practiced on a junk carb using a hacksaw to cut off the horn, then used a die grinder for final finish work. Other than the milled finish the results were identical.
57fairlane
560
Oakwood, GA
Jan 4, 2009
  • Jan 4, 2009
I did mine but I would imagine any competent shop with an end mill could do it.
A
Arron Johnson
Banned
Dec 30, 2008
31
Sonoma, CA.
Jan 4, 2009
  • Jan 4, 2009
Milling the air horn is done to increase flow, BUT there are some bad sides to it in some situations when the carb is exposed to open air (no air cleaner at high speeds).
Milling the choke horn is no big deal. We use a mill but you can easily do it with a simple die grinder and a carbide burr. Even when we mill them, we still go in and contour it with a die grinder, then hit it with a sanding roll to smooth out and remove any sharp spots on the edges.
Contrary to popular belief, milling the air horn won't do anything for a small engine. It'll only come into play at very high flow rates (large cubic inch engines with lots of air flow / velocity or... smaller engines at very high RPM's) How often is your mustang "running" at 7,000 - 8,000 RPM?
The down side to milling the air horn is that it prevents the choke horn from "straightening out" the incoming air charge. In other words, it acts like a wind tunnel, putting a cleaner, straighter, less turbulant flow pulling through the boosters, (and on 3310's, through the vacuum secondary siphon hole). It makes the carb more responsive at lower RPM's by having it on there.
You have to keep in mind, just because you see things like this done on race cars doesn't mean it works on street cars. Even in some race applications, milling the air horn is a no-no if the carb is out in the open, or isn't directly under an air scoop. This is because at high speeds, air passes across the top of the carb and can actually pull air back out, starving the carb. You need air to get down inside the carb, not skate across the top, which causes a siphoning effect on the carb, which can actually starve the carb for air.
Just remember, it ain't Holley's first day. ALL of their street carbs have air horns for a reason. Their race series carbs (such as thei HP series) don't have air horns because they figure this kind of stuff is taken into consideration.
Removing the choke assembly is a popular task, and we do it on pretty much every Holley we use. Holley's don't really need a choke. Pump the gas 2 times when it's cold and fire it up. Just keep your foot in it for abouit 1 minute, until the engine begins to warm up, and you're good to go. Using a choke on a Holley "can" making it easier to flood the engine.
Hope that helped
R
ron67fb
1,117
SF Bay area, CA
Jan 4, 2009
  • Jan 4, 2009
Any kind of choke plate position other than wide open will instantly flood my engine. I yanked the plate and let the choke control only the high idle.
My milled choke experiment was one of those "ignorant kid with a car" things I did, back when I thought modding for 1 extra horsepower at 6000RPM on a street car was actually worth my time.
woodsnake
1,352
15
69
Hicksville, NY
Jan 4, 2009
  • Jan 4, 2009
Ordinarily I wouldn't do this kind of mod, as I am a firm believer in the Holley line of products. The PO started in on it, and now it has is missing almost half on one side of the air horn. I guess the choke horn is the one that holds the choke plate, and the air horn is the 'back one'?
Anyway, I only am concerned about having an even air flow, and as it sits, you wouldn't think it would flow evenly. So I guess I will spend some time with a grinder and a sanding disc on my Dremel!
I'm kind of planning the carb for a 408/418 W with a roller cam set up at this time.
I know I won't really need a new carb for a while, and my 670 might have cut it, but I have a weakness when it comes to carburetors. I just keep buying them, knowing in my rational mind I need to stop!!!
Thanks for the tips!!
D
D.Hearne
11,730
south louisiana
Jan 4, 2009
  • Jan 4, 2009
I did a 650 DP using the hacksaw and diegrinder method as well. If you take the time and be carefull, there's nothing to getting a factory finish in doing this operation.
bnickel
5,640
lubbock, texas
Jan 11, 2009
  • Jan 11, 2009
i've done this also except i normally leave the remnants of the choke horn in place instead of smoothing and contouring it into the venturis, it will have absolutely no effect on flow if it is a street only carb.
has anyone seen holley's new line of all aluminum carbs? i guess they started making these in response to the Proform and Quick Fuel aluminum carbs.
65FBE2
283
Minnasnowta
Jan 11, 2009
  • Jan 11, 2009
Quick little trick I did after mill the horn and blending with a die grinder was to treat the exposed alum with gun blue. It stained the metal close to the original anodized finish and looked very professional
woodsnake
1,352
15
69
Hicksville, NY
Jan 11, 2009
#10
  • Jan 11, 2009
  • #10
Th gun blue is a good idea...
I'm going to go ahead and finish blending the air horn and bowls just for looks....
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
