Holley Systemax Intake vs Systemax II
Bullitt
Packin' Heat
2,743
Houston, TX
I've got a line on a used Systemax (original) intake. Do any of you guys know the difference between the original and the II??
Engine specs - 306, Lunatic 51017 cam (218/228 @ .050 w/ .536 lift), stock TW heads + Track Heat springs, 1 5/8" long tubes.
car made 325 HP to the ground with a carb and performer RPM intake @ 6500 RPM.
anyways, any differences between the intakes? it comes with a Ford lower, not Holley, but looks the same as the Holley lower on Holley's website. price is $375 shipped...
thanks!
Appears to be a BIG difference in port size.
attachment.php
Be careful. The Holley Systemax lower intake is almost an identical match to the GT-40 lower. I know this because there are folks that use the Systemax intake in combination with a Kenne Bell setup for a GT-40. It was my understanding that when they swapped over the larger lower intake that it's name changed to Systemax II (this could be wrong but just be mindful of it). If that is true, then the plenums you pictured above are both Systemax II --or-- they will not mate to one another. Look at both to be sure.
Brad's Picture above is correct for the old Systemax intake.
RS200 said:
In the pic the guy gave you, that is a Ford truck lower intake & Systemax (II?) upper. The comparison pic shows that the Systemax was basically a stock configuration. If it's truck style, it's II...I guess. :shrug:
Yeah, I was wondering WHY that lower looked like a Holley lower, but has a Ford emblem on it.. I've never seen a truck intake like that??? But it def is a factory Ford part.
attachment.php
I was under the impression that the manifold on the left(systeMAX) was a ported lower to the stock 5.0 HO motors from 86-94. I recall the sales rep. at Holley saying that there is only one systeMAX II set. The prototypes first gen. were a truck lower and the holley upper then Holley started producing their own lower to match the upper. I would suspect no defference in the two. Good buy for the price, I wouldn't pass it up.
i got the intake, thanks for all the help.
one question though, i have the Ford Motorsport "tall" valve covers to clear my 1.6 rockers. i've been told I need a 1" spacer with a holley intake for it to fit, is this correct?
The Holley Systemax (original) was just a lower. It used to come as a kit with a cam. They scraped it because it sucked. Then they cam out with the II, which is a good intake. They also came as a kit with heads and a cam.
As for the lower the guy is trying to sell, it is deff. a Ford factory part for a 302 truck. Back in the day, that was all racers had to use. I really dont know which upper they were using, but they were using that lower. I would keep on looking. That smeels like a scam to me.
