Holley Terminator X vs Megasquirt pnp2
  • Sponsors(?)
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,143
6,051
204
31
Hillsborough county
not apples to apples... imo you should be looking at the stinger pimpxs vs the terminator.
The pimpxs has way more capabilities than the terminator but the holley will come with a new harness.
The MS will require the purchase of a seperate WB, I suggest a spartan2
both are easy to learn.
I am biased toward MS although I have tuned many ems systems. they all have pro and cons, if you make a wiring mistake with the holley and loose an input ect, it is a paperweight... the ms can be opened and repaired, this to most users is not a reason to buy one over the other.
Reactions: ApacheGunRunner
DemonGT
642
Sparta,WI
Visit site
After looking at both im leaning more towards the MS for the reasons you said and i really dont wanna replace my harness.
Im also trying to research if using a aftermarket setup and tuneing it will give me the results i want.
Is there something that makes the spartan2 better then the Innovate WB? What is the easiest way to install the WB in the exhaust?
Can i replace a O2 with the WB sensor or do i need both O2's?
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,143
6,051
204
31
Hillsborough county
It boils down to this..
The ms2pnp is ms2 based this unit is actually at EOL.... meaning it will never see an update.
The stinger pimpxs is a licensed megasquirt product built specifically for the ford eec iv platform. It is ms3 based and is still being updated currently with new firmware, it is vastly superior in comparison to the ms2. And the stinger pimpxs is sequential injection to the ms2 batchfire.
I always suggest the spartan2 or spartan3 adv... it's what I trust in my own car, the spartan2 comes with a calibration sheet to get it dialed in correctly, the innovate tend to die abruptly and have voltage offset issues.
Reactions: DemonGT
GodStang
33
40
I was recently looking into WBs to replace my old one. So so many issues/complaints with all the Innovate's. I ended up doing dual 14point7 ADV 3 and they are very nice. My two replaced my rear O2 sensors on my car.
a91what
SendMeUrDataLog
Mod Dude
Apr 6, 2011
10,143
6,051
204
31
Hillsborough county
I hope the wb are placed before the cat converters
DemonGT
642
Sparta,WI
Visit site
Im not sure what sequential and batch fire mean? My motor is a N/A 410W..using 42lb injectors if that matters?
Sounds like the Pimpxs is the better choice. If i buy a spartan2 do i need a gauge or dose it just hook right to the pimp box?
Dose the pimpxs has the auto learn feature like the mspnp?
im redoing my dash with a florida5.0 insert and im just going to run a speedo/fuel level and WB gauge. not sure what the gauge
options are for the spartan2? One thing i liked about the Innovate is i could change the face to match the other gauges.
Ray65-71-73
23
Apple Valley, CA
Visit site
How about other options? I have a 427W in a 65 Mustang. In early 2019 I bolted on a FiTech port injection system, with 80# injectors, and also running the ignition.
I did it by-the-book. And then drove the Hot Rod Power Tour, and went to the NSRA nationals, about 6K miles each trip.
It runs like it knows what it is doing.
DemonGT
642
Sparta,WI
Visit site
If i buy the Pimpxs with a single WB id assume i can add a second to the other side later on if i decide to?
For the WB to function i just need the Spartan2 with sensor? i dont have to have a physical gauge do i?
Thread starter Similar threads Forum Replies Date
A Holley Terminator X Max (EFI and Transmission Controller) 1965 - 1973 Classic Mustangs -General/Talk- 3
Noobz347 Came Across This: Holley Efi Terminator X for your Fox Body Mustang Digital Self-tuning Forum 28
Mystang66 Holley 4180C question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
88LX5.Oh Digital Tuning Holley EFI vs factory EEC Fox 5.0 Mustang Tech 33
LILCBRA 14point7 Spartan 2 install, Holley 4150 tuning, & exhaust escapades 1974 - 1978 Mustang II Talk & Tech 102
H Holley EFI High Altitude MAP scaling? Digital Self-tuning Forum 7
Ragtop50 SOLD New Holley HP 550-606 EFI kit with TFI Harness & Knock Sensor ** NEW ** Engine and Power Adder 1
R Fuel line from pump to Holley 1965 - 1973 Classic Mustangs -General/Talk- 2
S Should I switch to the Borla ATAK or keep it classic Holley Blackheadt 2015+ (S550) Mustang -General/Talk 0
Woody3882 Holley 350 on my 65 Mustang question 1965 - 1973 Classic Mustangs -General/Talk- 6
1995COBRA Anyone convert to FiTech or Holley Sniper.. what was really involved in the swap ? 1994 - 1995 Specific Tech 18
P Holley Sniper shift light 2005 - 2014 S-197 Mustang -General/Talk- 0
L For Sale 1968 Mustang Coupe - 5.0 with Holley Sniper EFI - Houston, Texas Classic Mustangs For Sale 2
paddyrk Electrical 1991 LX 5.0, radio wiring help, ECU swap Fox 5.0 Mustang Tech 2
G Engine 85 302 holley carb. Car suddenly started to bog and sputter untill it stalled Fox 5.0 Mustang Tech 3
killer5.0 Haltech vs Pro-M vs Holley...thoughts? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 51
S For Sale 71' SCJ #6127 OE Holley carb D1ZF-9510-YA Other Classifieds 1
S For Sale 69' SCJ 428 Mustang list #4279 Holley carb Other Classifieds 3
moneypit94 Electrical Getting stock tach/speedo to work after holley efi install? Fox 5.0 Mustang Tech 3
smokin95vert Holley Efi Help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
V Holley Carb Question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
D Holley 650 Dp Stalling 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
EDC Holley Hi-ram For The 9.5 Deck Ford Fox 5.0 Mustang Tech 5
W Holley Carb Secondaries Problem 1965 - 1973 Classic Mustangs -General/Talk- 1
SemperFIGOD 306 Turbo Or 357 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
65Ccoderagtop Holley 7448 2 Barrel 1965 - 1973 Classic Mustangs -General/Talk- 0
sen2two Tps Sensor And Holley Throttle Body 1994 - 1995 Specific Tech 0
moneypit94 Dominator Ecu, Holley Cow 1994 - 1995 Specific Tech 0
MikeH686 Holley Hp Efi 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
M Which Ecu Should I Buy? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
84Ttop Holley Intake Manifold 2015+ (S550) Mustang -General/Talk 11
Grn92LX Anyone Using The Holley Efi System? Fox 5.0 Mustang Tech 8
90sickfox Build Thread Dusty's...King Of The Hill 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2309
Edster Holley 4180 Junk Or Workable? Classic Mustang Specific Tech 1
M Help Id This Holley Carb 1965 - 1973 Classic Mustangs -General/Talk- 0
T Use Of Holley Hp Efi For 96 Gt Sohc 1996 - 2004 SN95 Mustang -General/Talk- 1
callys Holley 750 Vacuum Help - Very Rich At Cruise Classic Mustang Specific Tech 2
L 1990 Lx 5.0 Holley Systemax Ll Runs Horrible Fox 5.0 Mustang Tech 10
viciousride SOLD Brand New Holley 120 Lb/hr Fuel Injectors (8) Other Classifieds 3
7991LXnSHO Holley, Bg, Demon Carbs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
fiveohlover What To Expect From Comp Polymer Box Upper And Gt 40 To Switch To Holley Sytemax Or Tfs R Intake 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 58
fauncekyle SOLD Holley Adjustable Fuel Pressure Regulator Engine and Power Adder 0
P Holley Systemax Problem... Fox 5.0 Mustang Tech 2
sen2two Holley Systemax Intake Question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
Kim Squires Holley Carb Restoring 1965 - 1973 Classic Mustangs -General/Talk- 0
GoldenEagle91 Fuel Tuning The Electric Choke On Holley 4bl Fox 5.0 Mustang Tech 5
7991LXnSHO Holley Colored Pump Cams 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
toxzzic1 SOLD Holley 512-500-1 Ford Mustang 5.0l Efi Adjustable Fuel Pressure Regulator **new** Engine and Power Adder 0
moneypit94 Stock Fan Relay And Wiring Questions To With Install Of Holley Efi 1994 - 1995 Specific Tech 11
