6 66bluepony New Member Nov 7, 2004 75 1 0 Sep 6, 2006 #1 Sep 6, 2006 #1 A while back, some one had a plan for a toe in gauge, it was a piece of alum. bent 90 with a small cut for a tape measure to fit in, you need 2 of these. Any one remember the site or know where you can buy these.
brianj5600 Active Member Sep 19, 2003 1,964 2 39 Middle TN Sep 6, 2006 #2 Sep 6, 2006 #2 Any circle track store. http://aolsearch.aol.com/aol/search...7bac&invocationType=keyword_rollover&ie=UTF-8
6 67GTFB Member Nov 29, 1999 122 4 19 Sep 6, 2006 #3 Sep 6, 2006 #3 a site or two ... try these ... http://www.drivewerks.com/tech/home_alignment.htm http://s2.pegasusautoracing.com/2006/097.pdf#search="toe gauge aluminum tape measure" http://www.stockcarproducts.com/long11.htm http://www.longacreracing.com/catalog/item.asp?id=152&catid=5 http://www.spectorracing.com/catalog/category_440_Front_End_Set_Up_page_1.html http://www.sr20forum.com/archive/index.php/t-29158.html etc .... Google rocks .... hope this helps .... I made some "plates" from mdf -- works the same way .... good luck .... 67GTFB
6 66bluepony New Member Nov 7, 2004 75 1 0 Sep 6, 2006 #4 Sep 6, 2006 #4 Toe Yes found it at longacreracing.com. Thanks all.
