I have a 1989 Mustang GT. Fresh bottom end rebuild, ported an polished gt40 iron heads. Now on the the questions. I am planning on running a single turbo about 6-8 psi.
1. What is the problem with just running the turbo off one header only, do I have to run a cross over from one header to the other?
2. Do i put the massair sensor before or after the turbo?
3. Do I need an intercooler for that low of a boost level?
4. Are 24 lb injectors and a 255 lph fuel pump enough to do what I am trying to do?
5. I am going to be getting all parts from a junk yard. What would be a good car to get a turbo and accessories off of? Volvo?
6. On a turbo with an internal waste gate, that is what controls boost right?
7. I will need a blow off valve correct?
8. Do I need an fmu, boost retard box?
Thanks
Thanks
